Alarm Problem - Will not switch off.
Old Mar 15, 2009 | 02:21 AM
K4RL's Avatar
Default Alarm Problem - Will not switch off.
Car has been sat around for a while, have just reconnected the battery but the alarm keeps going off and will not switch off.
the light on the fob comes on when i press the off button but the alarm keeps going off .
What things should i be looking for?
cheers guys
Old Mar 15, 2009 | 02:24 AM
motogp1's Avatar
Your battery is going flat or its screwed , charge it and try again.
Old Mar 15, 2009 | 08:30 AM
K4RL's Avatar
Battery is fully charge. The Alarm does not seem to recognise the fobs.
Old Mar 15, 2009 | 08:33 AM
lovegroova's Avatar
Try starting the car and then let it run for 30 secs. That might fix it.
Old Mar 15, 2009 | 09:31 AM
mobile chicane's Avatar
you may need to re learn the fobs to the alarm, depends on what type of alarm you have and if it has an overide code or a reset fob.
Old Mar 15, 2009 | 09:37 AM
FunBox's Avatar
Either the battery or the bonnet switch? Try prodding the bonnet switch a few times.
Old Mar 15, 2009 | 12:21 PM
K4RL's Avatar
right i have the standard honda Alarm comes with the two button Fob.
Cant Start the car because of the imobiliser. (the alarm is still going)
I dont have a reset Fob, how do you relearn the fobs to the alarm.
Bonnet Switch ? what for the alarm ?
cheers
razzele
Apr 20, 2013 12:31 PM
bluenomad
Mar 13, 2010 04:40 AM
Stiggywig
Feb 18, 2008 12:31 PM
Ant09
Oct 8, 2006 09:48 AM
all-trick'd-out
Apr 22, 2004 09:28 PM
