Auxiliary power leads
Old Jul 20, 2012 | 04:36 AM
mike5im5's Avatar
Default Auxiliary power leads
I just fitted the modifry seat belt lock yesterday and the electromagnetic solenoid does not appear to be engaging when I flip the switch.
Can anyone verify whether I connected it to the correct auxiliary power wires in from the loom behind the passenger seat?
As per instructions it said use the black wire and the red/white wire. There were a lot in here and I just want to confirm that I have the right ones and that these aren't different between UK/US models?
Old Jul 23, 2012 | 09:54 AM
mike5im5's Avatar
Just a little bump and update on this.
I wired up the seatbelt lock to a cigarette adapter and fitted it directly to the 12v auxiliary power plug and the seat belt lock works perfectly. So appears as if the wires shown above are incorrect.
Does anyone know the correct wires for the12v aux power supply? Failing that, what's the easiest way to get the aux power plug off to take a look behind? I'd rather not remove the entire glovebox if possible.
gravesdu_99
Aug 23, 2012 04:46 PM
tbonesteak
Dec 25, 2006 10:38 PM
richpass
Jan 19, 2005 06:47 PM
Xd
May 3, 2004 11:03 AM
lachambers
Jul 16, 2003 07:33 AM
