Aww Bugger!
Old May 16, 2006 | 11:03 AM
Phil_gb's Avatar
Default Aww Bugger!
After 6 trouble free months of S ownership I had the need to remove the wheels for the first time today, as I have a looming trackday and wanted to give the car a thorough check round.
So got the locking wheel nut, tried the drivers side front first, wheel brace on loads of pressure - no movement. So try the passenger side, hardly any pressure then crack, the sticky out bit (technical term) sheared straight off. Looking inside the bit that came off it is clear to see that the nut was badly corroded.
Anyone had any similar trouble? Was it relatively straight forward to have the broken nut removed?
Also given the lack of movement on the drivers side i'm a little nervous about trying to remove the nut from this side now any tips as to getting it off without this one breaking.
Thanks in advance!
Old May 16, 2006 | 11:10 AM
MB's Avatar
MB
Member
You mean the plastic cap bit?
Happened to mine. I used an awl / spike on one of the flats and a large hammer to beat it round. Took a couple of whacks and it was off.
MB
Old May 16, 2006 | 11:13 AM
Chris Type R's Avatar
I think that the locking wheel nuts shipped with the MY00-MY01s were kack, & this has happened before. The newer cars shipped with rebadged McGards, which are less prone to this.
There are tools to remove locking wheel nuts - if you google, you'll find someone / something. It depends on how much of the nut is still attached to the stud.
Old May 16, 2006 | 11:14 AM
Bada Bing!'s Avatar
Banned
Done that before. Hammer an old socket on top and mash it in place, then turn the socket. Job done
Here's a link, which I'll remove in a few hours:
http://www.buyacar.co.uk/AccessorySearch.j...2pc+21+%26+25mm
Old May 16, 2006 | 11:17 AM
Rabbie_boy's Avatar
Try going for a drive in it and get the brakes hot, this will expand the disc/ hub and might be just enough to free the wheel nut. Or give it big smack on the head with a hammer.
Old May 16, 2006 | 11:32 AM
Fieldl's Avatar
I did the same a few months ago.
Complete PITA ended up getting someone to drill them all off
Old May 16, 2006 | 12:01 PM
Phil_gb's Avatar
Cheers gents will try a few of the above.
It was the little cylindrical bit between the plastic 'cap' and the main part of the nut itself which sheared off. So the socket will still go over and the pins will still go in but it won't have a 'guide' if you like.
Its really hacked me off, cos I still dont know wether I'm gonna need new brake pads yet, cos I can't see clearly enogh with the wheel on.
fatbaldboy
May 16, 2014 07:43 AM
ryanswhites2k
21
Jan 22, 2014 04:26 PM
stu_c
Mar 19, 2011 09:38 AM
FurballS2000
Jan 25, 2011 04:05 AM
s2kjunkie
Aug 19, 2004 06:08 AM
