Blackpool
Old May 23, 2011 | 10:25 AM
Hawki's Avatar
Default Blackpool
Hi
Old May 23, 2011 | 10:37 AM
loftust's Avatar
Shift slower and bear in mind that second is not directly down from first, it's down and to the left slightly.
Old May 23, 2011 | 10:40 AM
MB's Avatar
MB
Member
Gear shift should be perfect imo. Maybe there is a nearby owner who will let you try theirs to compare.
Old May 23, 2011 | 10:59 AM
AquilaEagle's Avatar
Administrator
When did you last change gearbox oil, and what is it using?
Old May 23, 2011 | 11:58 AM
Cazzcat's Avatar
Hi, I'm in Southport so fairly close to you. Whilst I know absolutely chuff all about gears mine has always been quite clunky changing from first to second when cold, gets better when warm though. I also have a 2005 with 19k miles, happy to meet up and compare if that would help?
Carolyn
Old May 23, 2011 | 12:15 PM
Cazzcat's Avatar
No problem, give me a shout if I can help, I don't mind heading your way. Is the promenade open again yet?!
I was lucky to find my 2005 with low mileage, it was a one owner 4 year old car with 11k miles when I got it almost 2 years ago. I work 4 miles from home so the mileage stays fairly low
Old May 23, 2011 | 12:31 PM
Bramblecat's Avatar
I have an 04 and mine's a bit clunky from 1st to 2nd when the box is cold it certainly a lot smoother when the oil is warm. Had an oil change soon aftr getting mine (19,000 miles) made it a little better I've now got 28,000.
Old May 23, 2011 | 11:05 PM
philgally's Avatar
Hi mate,
This is probably my 1st post on here, but I have been browsing the forum for about 5 years!!
Anyway I have a 2002 and I'm in Blackpool, you're welcome to come and have a feel of the gears etc. I don't think it is any worse than when I bought the car and I believe it is spot on. Send me a PM or something.
Thanks
Phil
Old May 26, 2011 | 12:05 AM
Nezquick's Avatar
I also have a 2005 with 28,000 on it. The change from 1st to 2nd is clunky but eases up considerably after a service and a chage of gearbox oil. Once the engine is warm though, it's fine.
I'm in Preston if you need any help.
Old May 26, 2011 | 05:14 AM
sound_wave's Avatar
Bit of a further drive, but I'm in Warrington if you want another opinion?
