Bonnet Catch Problem
Old 02-24-2011, 11:02 PM
Rob88's Avatar
Default Bonnet Catch Problem
My bonnet catch is no longer working.
I pull it from inside the car and it pops open, but it's not locking back down.
I can manually push the cable back through the hold from the drivers seat and it will close and latch, but I have to do this every time.
I presume some sort of tensioning spring is knackered.
Does anyone know if there's an straightforward fix for this without dismantling the entire front end of the car>
Old 02-24-2011, 11:06 PM
UK Moderator
lovegroova's Avatar
If the spring is broken, which is what happened to mine, you need a new bonnet catch - £30-£35 from a dealer.
There are two springs, so it's easy to tell if that's the case.
Old 02-24-2011, 11:07 PM
WinFreak's Avatar
Take the catch mechanism out and clean/oil it a bit, common problem on many Hondas this is
Old 02-24-2011, 11:40 PM
Rob88's Avatar
Great Thanks,
I'll do some screwdrivering this weekend.
I assume that even with a knackered spring the bonnet is still held safely when clipped right down.
Anything tricky about the catch in general to be wary of?
Do I need to dismantle the catch to release the cable or does it unclip easily?
Old 02-25-2011, 06:39 AM
richmc's Avatar
hi Rob, just looked in the pdf manual in the faq, looks like an easy one half a dozen screws, If its a spring it might be worth asking at the local (not Halfords) motor factor rather than paying out for the whole thing and looks like the cable slots out.
Old 02-25-2011, 06:46 AM
richmc's Avatar
And just found this-
hope it helps
torroxdrifter
01-25-2016 03:32 AM
tomkbucks
01-17-2011 12:12 PM
GrittyShaker
03-11-2010 05:24 AM
lovegroova
12-31-2009 10:06 AM
TexanS2000
03-07-2007 01:14 PM
Quick Reply: Bonnet Catch Problem
