Bourbon's S6000
A couple of things to help you
Power has nothing to do with a diff. Torque does a little bit.
The key here is GRIP.
The maximum loading put on the diff will be limited by traction. Unless you plan on going crazy tyres/slicks with full bore clutch dumps the standard diff will be fine.
I now understand it a bit better thanks to your pointer and it is at this point that I must confess that I own a pair of drag wheels and tyres and will be hooning it down a drag strip later this year. Also I'm planing on having around 255 tyres on the rear for road and track use.
So because I will be giving the car a hard time periodically it does say to me upgrade and don't be embarrassed at the starting line of a drag strip with a popped diff.
I have a spare S2 diff just incase I did break the standard but I've got the feeling I should just jump in and change it as soon as.
I'll put a video up if I remember to record one
And don't worry about embarrassment! What you want/need to do is get the car built. If using the standard diff gives you one less thing to worry about it's a good thing.
Surprise!
It's been awhile ..
Work had been halted by the two poster ramp that the car is on being disconnected.
The place where the car is are moving to a new premises hence the disconnection.
Yesterday before the NW meet (which was really good btw!) I managed to get a friend to wire it back up, so in about half an hour I'll working on the monster again!!
Engine needs moving back 5-10mm and up 10mm.
A couple of other tidying bits too as well as measuring for front support members.
It's booked into exhaust shop for the 28th January, should be away less than a week then it's fueling, wiring, plumbing ... Shit there's still quite a lot to do ... Haha!!
It's been awhile ..
Surprise!
It's been awhile ..
It's been awhile ..
Can't wait to see/hear the V8, hope the rest goes smoothly
I thought it was common knowledge!!
It didn't go too well today, the engine needs raising another 15mm.
Though it's now far enough back for the steering rack to clear the crank pulley!
I need to make some new engine mounts to give me the extra height required.
Working this weekend so I won't get to play until Monday.
