Bourbon's S6000
Old Jul 26, 2014 | 04:22 AM
  #821
Toms1989's Avatar
Hahaha that sounds so wrong coming yet so amazing! You and your mates reaction of the first rev was priceless haha!!!
Old Jul 26, 2014 | 12:50 PM
  #822
remasters's Avatar
sounds awesome, would love to see this in the flesh
Old Jul 26, 2014 | 10:52 PM
  #823
earl's_f20c's Avatar
Originally Posted by mr-pitts
Originally Posted by earl's_f20c' timestamp='1406294836' post='23259031
Kin-ell I can't see any vids as I'm at work!!
Well fcuking done though dude!!
Your language sir is despicable and you spelling is even worse.
Fcuk off no way iz it !!!
Old Jul 27, 2014 | 01:47 AM
  #824
GTFCTIM's Avatar
Originally Posted by Carl Bourbon
Originally Posted by GTFCTIM' timestamp='1406331681' post='23259874
Grimsby town?? I'm always in Grimsby, live just outside it.
I often see a couple of S2s, which is yours?
Sold mine ~6 years ago
Live in Keelby.
Old Jul 27, 2014 | 01:48 AM
  #825
Carl Bourbon's Avatar
Having a couple of technical issues, fans don't seem to be kicking in, despite having a temp sensor from the S2 block screwed into the v8 and plugged in the honda harness I'm not getting a temp read out on the dash, it says low but I know it's pretty warm, I can barely touch the rad it's that hot.
The modified pressure cap doesn't seem to have worked.
Old Jul 27, 2014 | 01:50 AM
  #826
Gutted, I used to live in keelby, the limes and then woodlands avenue!
In stally now, if you ever want to pop over don't be shy!
Old Jul 27, 2014 | 03:11 AM
  #827
mr-pitts's Avatar
If push comes to shove get independent temp sensor and fan switch.Ive got a Kenlow fan system that has its own thermostat/temp sensor that fits into the rad fins.Ive got an independent temp sensor also but that is connected to my retech dash.
Old Jul 27, 2014 | 04:43 AM
  #828
GTFCTIM's Avatar
Old Jul 27, 2014 | 07:08 AM
  #829
Think I got to the root of the problem, air lock in the coolant, jacked front end up and loads of bubbles came out, warms up quite quickly but when up to around 85-88 it steadies out, got it to 93 still no fans, looking at the map4000 program I think they're set for 100 but the whole car died. Lost the ignition live that we'd used for a bunch of relays, burnt out the 7.5 fuse. As a temporary fix I've chucked in a 15A but when I have time I'll get another relay and use that singular one to then kick the rest of them in and I'll reduce the fuse size back to 7.5A.
My friend with the laptop had to leave so we still haven't got round to getting fans to kick in, that's tomorrow's job.
Switch back to standard rad cap rather than the skunk2 one and no leaks since, though I think it was because it wasn't bled properly.
I ought to get an independent temp sensor for coolant and another for oil pressure. It's on my list of things to do.
Probably going to remove one of the two springs on the throttle body as it is very stiff and it's hard not to rev up to 2K when trying to put on a little bit of revs.
Old Jul 27, 2014 | 12:09 PM
  #830
Had a nap before my night shift and whilst asleep I seem to have figured how I want to go about the throttle.
Currently have a modified ek9 cam which is very round, not progressive at all. But the size of it means I can get WOT and it be quite stiff. If I was to get another cam or replicate it and offset the pivot point lower then it would pretty much make it a progressive action which would increase driveability. It’d be stiffer nearer WOT but easier to regulate the lower down revs which is ideally what I'm after.
Had a quick chat with Luke from tegiwa regarding the speedo and eps, the sensor for the speedo has to be very close to the pickup wheel, like VERY close. I thought it was close enough but I can probably get it closer so I'll be giving that a shot tomorrow and when that's sorted the EPS will return as well as it's reliant on the VSS. Unless I've chopped a vital part of the Honda loom out.
