Brake fluid capacity
1 Post
I'm planning on installing my Goodridge hoses soon, and I was planning on uprating the brake fluid as well. Everyone seems to rate Motul RBF600 so I thought I'd give that a try.
Can someone tell me how much I would need to refill the whole system?
1 Post
Originally Posted by Paper Lawyer,Feb 22 2007, 12:49 PM
A couple of tubs IIRC
Thanks for the link in your sig as well
1 Post
I purchased two bottles of RBF600 (0.5L each) and I had a little bit left over. So yes, 1L will do for a full flush.
Also I got myself a one way valve with a bit of rubber tubing on it. I attached it to the bleed nipple, opened the nipple and got my mate to slowly pump the brake pedal. When he lifted off the pedal the valve would prevent any air getting sucked back into the brake lines. It really speeded up the process.
I think you can get them down your local Halfords.
Gravity bleed is how I'll be doing it in future. Just open the bleed screw, then go make a cup of tea.
Halfords 5.1 in mine. I've never been convinced all this fancy brake fluid is ever worth it.
1 Post
Originally Posted by Dembo,Jul 13 2007, 12:47 PM
Even with the valve the bleed screws let in air. If there's two of you, then one of you should close the bleed screw before the other lets off the pedal.
I guess when it comes to brakes, I shouldn't cut corners.
OneSilverS2k
03-22-2011 02:51 AM
