Burning oil at low revs/pulling off
Old 04-18-2017, 05:37 AM
JDMCrit's Avatar
Default Burning oil at low revs/pulling off
Hello I'm new to this forum so apologies if this is the wrong section. I have an ap1 2001, When my car has warmed up to temperature I will be sat at the lights and as soon as I pull off there is a big blue cloud of smoke coming from the exhaust, it continues at low revs just not as thick as when I've been sat at idle and then pull away, it also happens at low speeds after i downshift. There is no smoke at higher revs just at low revs when I'm stuck in traffic for example, it only happens when the car is warm not when it is first started up, any help would be much appreciated!
Old 04-18-2017, 06:12 AM
kw_21's Avatar
Do you have a decat?
Old 04-18-2017, 06:35 AM
UK Moderator
lovegroova's Avatar
My old car used to do it when sat on a alight incline (for example, when getting out to open the garage door).
It was worse when the oil level was very high.
Old 04-18-2017, 08:04 AM
flanders's Avatar
Is the oil level above normal and what kind of oil are you using?
Sounds like you are pulling excessive oil in from the PCV.
You could try and disconnect it from the manifold just as a test, make sure you cap of the intake manifold fitting though.
Long term solution would be to connect a catch can in between.
Old 04-18-2017, 08:17 AM
JDMCrit's Avatar
I'm using mobil 0/40w and I just disconnected the pcv from the manifold and capped it and it is still smoking, the oil is halfway up the dipstick markings
Old 04-18-2017, 08:18 AM
JDMCrit's Avatar
Yes it is decatted and has single exit exhaust system
Old 04-18-2017, 09:18 AM
RobinA3's Avatar
What mileage has the engine done?
Old 04-18-2017, 10:12 AM
noodels's Avatar
Valve guides or seals
Old 04-18-2017, 11:11 AM
JDMCrit's Avatar
124,000 miles, I thought stem seals myself but people are telling me they are not the right symptoms?
Old 04-18-2017, 12:06 PM
CHIPPO's Avatar
Sounds like good excuse to keep revs up,beyond 6k
seriously try a heavier oil as well , 0/40 is a bit thin especially for pre 04 lumps. For some,mysterious reason. Sons F20c now in bits in the shed , we found all stem seals split at around 90 k miles
pre 04 cars will often use up to 1l per 1000 miles . Mine was checked twice for oil consumption when it had done 6k miles about 15 years ago and,was prounouced ok by Honda , not changed since and now done 80k miles
last weekend on a 200 mile round trip to silverstone it used about 1.5 x,s on the dip stick , and,certainly wasn't hanging around saw the red line quite often . I Never let it go lower than that , I change oil and filter every 3000 miles regardless.
Quick Reply: Burning oil at low revs/pulling off
