Bush outer shells
Old Feb 22, 2014 | 07:07 AM
  #21
jezer101's Avatar
Sorry I've misunderstood what the zerks are for.
So for them to work the bush needs a channel so the grease can get to the collar?
Old Feb 22, 2014 | 03:18 PM
  #22
flanders's Avatar
Correct, the powerflex bushing I got there was a small gap between the both bushing halves so was no need to drill through.
Old Feb 23, 2014 | 01:03 AM
  #23
CHIPPO's Avatar
I didn't have the slightest problem using hole saws , if they melted their way through the bushes I suggest the hole saw was blunt , they do get hot and touch of coolant is a good idea.
Sawed through the out shell in the housing with a hack saw couple of mins , careful not to go into the housing , punched them out with chisel
Copper slip and any lithium based grease is not the best. For poly bushes , water proof silicone is the way to go , food grade stuff stays put very water resistant as you don'twant it getting in your pies , ask fatty ! Copper slip is not for this type of application it's not a lubricant , it's not water resistant.
I was thinking about grease nipples as this is quite a common thing that is done in the states to classic cars when they have poly bushes fitted , I asked the question here if any one had tried but it was like asking the captain of the Marie Selest , no reply. I was concerned about weakening the housing , I can see that the ones shOwn in the pic as in a good place for future access but is that also not a high stress area , in heavy impacts etc where do these arms fail ?
I used some purpose made stainless washers between the poly bush ends and the steel housings on the subframe and body as the in face needs to move freely as the bush needs to on the crush tube as we'll
I haven't any noise or binding since it was done , will be checking on the general condition etc latter in the year when I get to spend a day servicing the car.
Old Feb 23, 2014 | 10:31 AM
  #24
loftust's Avatar
Heat kills blades, drill bits - any cutting edge tbh. A bit of WD40 helps.
Sent from my GT-I9300 using Tapatalk
Old Feb 24, 2014 | 12:28 AM
  #25
CHIPPO's Avatar
I cut all of mine out with 2 size's one of which was 29mm , and both the cutters are still in good condition. Use decent Starret ones which are bi-metal and last, even when subject to improper use and abuse. Good lube/coolant any thing to cool and provide a bit of lube is fine. Of course you can dispense with the pilot drill so thats one thing that will not break or wear out.
As for getting the caster bushes out using this technique yes its all down to a lots of drilling and the odd snapped drill, but then again its use and abuse of tools using them not in the way intended or designed. Resharpen drill sin any case even if snapped , make nice short stubb drills.
Old Feb 24, 2014 | 08:26 AM
  #26
noodels's Avatar
polybushed my last rear camber bush today 2.5 hrs,though done in situ.
Snapped my first Dewalt bi metal blade,
hole saw method worked a treat until i broke it !!though was my fault
Geometry next..
Talic
Mar 3, 2017 09:15 PM
boyguan
Jun 23, 2015 10:36 AM
TerminatioN
Mar 17, 2011 09:33 AM
SoCalIsMyLife
Aug 11, 2008 02:46 PM
