Cel code p1412
Old May 28, 2008 | 10:40 AM
a3lkx's Avatar
Default Cel code p1412
hi guys could someone point me in the right direction of were to look up error codes for my s2k please? just had it scanned and the codes show P1412 and the other code is p1411. the engine managment light is on, car feels fine and drives just as well as it always has.
thanks guys
Old May 28, 2008 | 10:53 AM
veehexx's Avatar
my sig should have the codes
edit: seems not...
Old May 28, 2008 | 11:19 AM
RISLAR's Avatar
Secondary Air Injection Signal, its likely to be an Vaccum hose has come loose
Old May 28, 2008 | 11:21 AM
a3lkx's Avatar
something to do with the airpump maybe? i have searched and searched can not find anythink
Old May 28, 2008 | 11:27 AM
RISLAR's Avatar
Check all lines first as it usually is a perished hose or that its come off or loose, you dont want to replace parts that are in working order
Old May 28, 2008 | 11:29 AM
RISLAR's Avatar
Read this fella:
https://www.s2ki.com/forums/index.php?showt...0&#entry7016187
Old May 28, 2008 | 11:32 AM
a3lkx's Avatar
www.troublecodes.net seem to think its emission related and its incorect down stream flow maybe from the airpump the piper are in the wrong locations? as it had a new airpump not so long ago, and the other code is low circut imput? what do you guys think?
Old May 28, 2008 | 11:33 AM
a3lkx's Avatar
p1412 is causing the mil not sure exactly what it is yet though?
Old May 28, 2008 | 11:40 AM
RISLAR's Avatar
This could also be down to a faulty relay for the air pump !! Have you had an airtake fitted recently?
Old May 28, 2008 | 11:42 AM
a3lkx's Avatar
not as such no a snorkel though but thats nothink is it. i think its the relay maybe or somethink to do with the airpump ill change the hoses around and see what happens?:S
