Clarification On Whether Working Headlamp Washers Are Now Part of MOT Checks
Old 07-31-2018, 05:35 AM
Rich 3's Avatar
Default Clarification On Whether Working Headlamp Washers Are Now Part of MOT Checks
As there seems to be some ambiguity over whether a non working headlamp washer is now (under the new rules introduced last year) an MOT failure I thought it may be helpful to share an official link from the DVSA which appears to clarify this:
https://www.gov.uk/government/news/m...es-20-may-2018
As you will see the above appears to clarify that it is only cars registered after 01/09/2009 that should be considered an MOT fail for non working headlamp washers. In which case the majority of S2000's should not be affected.
May be worthwhile people printing off the link off before taking their cars an MOT if they are concerned about any potential issues regarding this.
Hope that helps
nomadicS2k (07-31-2018)
Old 07-31-2018, 06:48 AM
UK Moderator
lovegroova's Avatar
More detailed explanation here: https://www.mot-testing.service.gov....ml#section_4.1
See section 4.1.6
4.1.6 Headlamp cleaning devices
You must inspect vehicles first used on or after 1 September 2009 equipped with headlamp washers.
You can identify HID headlamps from:
  • ‘DCR’ mark on the headlamp lens or body
  • an igniter module or inverter behind the headlamp
  • taking a few seconds to reach full intensity
  • a bluish tinge to the light
HID headlamps use high voltage. You should take care when inspecting these headlamps.
Defect............................................ .................................................. ...........................Category
  1. Headlamp cleaning device:
  1. inoperative....................................... .................................................. ..................Minor
  2. inoperative in the case of LED or gas discharge systems (HID).........................Major
Old 07-31-2018, 07:02 AM
Chuck S's Avatar
Received 1,134 Likes on 997 Posts
www.mot-testing.service.gov.uk -
Access Denied
Old 07-31-2018, 11:16 PM
Soggybottomboy's Avatar
Chuck S it is because you are outside the Uk. The link works fine for me.
Old 08-01-2018, 12:32 AM
richmc's Avatar
Originally Posted by Chuck S
Wonderful new data protection laws courtesy of the EU, loads of sites here come up with "Content not available in your country". PITA
Old 08-01-2018, 01:57 PM
ClumUK's Avatar
Mine failed on broken headlamp washer pump last year, does this mean the MOT has actually been relaxed in this particular area now?
Old 08-02-2018, 04:40 AM
martin j's Avatar
Is not a case of “if they are fitted they must operate”? Asked one or our mot testers but unfortunately we‘re busy today so it was a brief- if parts are fitted they must, they may not have been mandatory fitment before 09/09.?
Old 08-03-2018, 05:22 AM
mcrossley's Avatar
Asked my tester and he confirmed my disconnected '06 washers are no longer a fail.
Rich 3 (08-03-2018)
Old 08-06-2018, 07:58 AM
prince buster's Avatar
Put a cap over my washer switch years ago, got fed up with the wife falling on it.
ralper
08-14-2014 06:35 PM
BENJ13
03-09-2009 01:35 PM
sugarbear
10-22-2007 03:57 PM
dlq04
05-06-2005 04:12 AM
tokyo_james
10-25-2001 09:36 AM
Quick Reply: Clarification On Whether Working Headlamp Washers Are Now Part of MOT Checks
