Clutch pedal sticking
Hey guys really need help in this issue because its driving me mad....
I have an issue with the clutch pedal sticking when releasing but only if I've been using it alot ( Stuck in traffic )
Clutch and flywheel has been changed not to long ago by previous owner and the car seems to have been well cared for
any suggestions would be helpful
Mastercylinder, check.below the cluch there is a part that the pedal attaches to, this may well be leaking black grease or have alot of play in it. Replace. Its also worth greasing the large clutch fork, slave cyclinder and the selector parts below the shifter.
Hi and welcome along, there are quite a few posts on clutches, but I'd focus on
If you do a search you can find a lot of info on both, keywords: "clutch" and "nipple"
- changing the fluid
- de-nipple the slave rod and re-grease the ball
I've greased the ball but still sticking.
i have noticed the clutch fluid is filthy so i'm hoping if i change the fluid on the weekend that it may make a difference
there is a little bit of grease showing on the rod that attaches to the pedal, i wont to try doing the cheapest options first so i'l let you know how i get off with the fluid change
Thanks for the help
Thanks for the help
