Clutch problems :-(((
Ok guys got a problem with my clutch,basically when I pull away in 1st gear it judders like mad,it also stinks like its slipping.but once in gear it's fine,well I say it's fine-if I pullover it smells like its been slipping.the pedal doesn't feel the same either,the biting point is very low and feels spongy.
The thing that's doing my head in is that the clutch has got about 6000 miles on it,and it's the uprated act clutch/flywheel kit.
Do clutch delay valves play up??
Any help will be appreciated,thanks
Also how many hours does it take to change a clutch?
Suppose it's worth a try,I changed the fluid the other week when I did the brakes(ate super blue brake fluid)
My only other concern is that I spoke to a bloke at helix this morning,when I told him the act clutch is rated at 370lb he wasn't convinced,he started getting very technical and lost me lol,but he basically said I would need something bigger than a 212mm clutch disc,I think I might need a twin disc clutch.
