Clutch Slip
Old Apr 24, 2010 | 09:56 AM
Spies's Avatar
Default Clutch Slip
Firstly the car has only done 24k.
I was accelerating from a roundabout in to vtec in 2nd then straight into 3rd but the revs rose and then settled down again, I then came off the next slip road and tried again but this time from 1st in to 2nd and there was no slip, is it possible to slip between 2nd and 3rd but not 1st or 2nd or is my left leg just not fast enough?
Old Apr 25, 2010 | 12:37 AM
gbduo's Avatar
There is more torque in 2nd to 3rd, so it is possible, but I would try again and see if you can replicate the problem.
With that low mileage I wouldn't have thought the clutch would be slipping already and could have been an isolated event and nothing to worry about! But see if you can get the car to do it again.
Old Apr 25, 2010 | 01:05 AM
Jayboy83's Avatar
have you only had the car a little while?
when i first got mine i had this for a short time, mostly due to me trying to change gear as fast as i could. It pays to do it a little slower and be sure your left foot is completely off the clutch, cos thats what its most likely to be. After me having the car a month and using it a fair bit it hasnt done it since, even with me changing gear fast and probably still not coming off the clutch as quick. I think my car had been sat around for a while and needed driving to wear it in or something. Or maybe im more aware of getting off that clutch quicker, although i couldnt accelerate to hard with the revs high to start with either cos the clutch would just spin, but now its only the wheels that do!
Old Apr 25, 2010 | 01:16 AM
unclefester's Avatar
Are you sure it's not the clutch delay valve thing kicking in?
Old Apr 25, 2010 | 04:17 AM
Spies's Avatar
Could well have been, it was quite a fast sharp change...
Old Apr 25, 2010 | 04:26 AM
Jayboy83's Avatar
i never considered it being that when i experienced it. Although i never seem to get it slipping anymore.
Old Apr 25, 2010 | 07:37 AM
RedUn's Avatar
Sounds like the CDV to me. It's fairly easy to remove or fit a pre 04 slave cylinder.
Old Apr 26, 2010 | 03:24 AM
GavB's Avatar
Remember commenting on this before:
https://www.s2ki.com/forums/index.php?showt...&#entry13295724
I don't think you have a problem, other than being too quick on the gas and the CDV not helping.
Old Apr 26, 2010 | 03:37 AM
MIP's Avatar
MIP
I found the clutch delay valve a hateful thing on track, ditched mine asap.
Old Apr 26, 2010 | 05:08 AM
Spies's Avatar
If it's normal I won't worry then. But yes it was a hard, clutch in, 3rd, clutch out, foot down HARD change.
S2KERRP2
Aug 29, 2015 08:21 AM
_2K1S2K_
Jul 22, 2013 08:05 PM
fishs2000
May 23, 2009 11:15 AM
junehhan
Sep 11, 2002 12:41 PM
Speedster
Jan 18, 2001 05:38 AM
