Condensation in headlights
Old May 27, 2008 | 12:00 PM
  #21
j8mie's Avatar
Originally Posted by PJD,May 27 2008, 08:55 PM
Hmmmm - so even once the condensation has disapeared (after leaving the cap off) - the act of putting the cap back on produces condensation again?
In which case I guess I'll have to leave the cap permanently off.
Or as you suggest making holes..... - or, buying a new lamp!??
Am I right in thinking there is somekind of second layer of protection covering the back of the light? Doesn't the wheel arch lining folder over it or something?
If that's the case I would make a small hole in that rubber cap, refit it and take it from there. Otherwise I would be reluctant to leave that rubber cap off altogether.
Old May 27, 2008 | 02:11 PM
  #22
noizyboyz's Avatar
All air has moisture in it, when you cool the air (cold surface like the glass) the water condenses. You have 2 choices; dry the air and seal the system (like your double glazing) up or let it equibrilate (plenty of ventilation). Once the moisture gets into the headlight unit it is it's own micro climate so you need to dry it out, otherwise everytime it gets cold you will get condensation.
Old May 28, 2008 | 01:14 PM
  #23
PJD's Avatar
PJD
Thanks noizyboyz - as I said above - i did dry out the lamp and resealed it... - but moisture has reappeared...
Old May 28, 2008 | 11:53 PM
  #24
Simoted's Avatar
I tried drying my headlamp out, then re sealing it to no avail. Removed the rubber seal over a year ago, my car is not garaged and its used every day and the condensation has never came back and I've had no problems at all
Old May 29, 2008 | 12:16 AM
  #25
Nottm_S2's Avatar
i think some of the lights have poor seals - hence the ricks advice. the extra moisture will leak in from wet weather, washing etc.
mine does it and i just left the rubber seal slightly off on one side and it seems to solve it but it's not a daily driver these days so only gets wet when i wash it...
Old May 29, 2008 | 05:07 AM
  #26
PJD's Avatar
PJD
So it appears that leaving the rubber cap off altogether shouldn't have any adverse effects.... - I think i'll do that.
A single steamed up headlamp is SO 'king annoying!!!!!
Cheers lads
Old May 29, 2008 | 05:49 AM
  #27
RevRanger's Avatar
Originally Posted by GrittyShaker,May 12 2008, 11:06 PM
I need to do mine too. My headlights are steamed up pretty badly. Never fully read the destructions on how to do it.
I seem to remember Goldfish in yours due to the amount of water!
Albert
Jul 19, 2021 08:04 AM
Kinger01
Apr 25, 2015 11:00 AM
Bandit_287
Sep 16, 2011 03:00 PM
enguyen7292
Jan 18, 2002 02:51 AM
