Connect charger through accessory socket?
Old Jan 30, 2008 | 09:53 AM
PaulWil's Avatar
Default Connect charger through accessory socket?
Does anyone know if it is possible to connect a battery trickle charger (or conditioner) through the accessory socket rather than running a wire to the battery posts?
Or does the key need to be switched 'on' in order to establish a through connection?
Old Jan 30, 2008 | 10:14 AM
Shopman's Avatar
As you say socket is switched off with ignition so it won't work.
You could install an extra socket wired into the 'constant' connection near the fuses.
I have two extra sockets under the dashboard to run GPS and radar.
Old Jan 30, 2008 | 11:26 AM
PaulWil's Avatar
Thanks (and tks for the pic) - just what I thought. Pity - it would have been a neat solution.
I'll probably just run a wire from the battery posts thru to the cabin.
Old Jan 30, 2008 | 08:41 PM
atomcrusher's Avatar
If you do that, make sure you include an in-line fuse on the live / positive conductor wire. The fuse should to be rated according the the amperage rating of the charger, i.e. if you use a trickle / conditioning charger with, say, a max output of 2.5 AH, use no more than a 5 A fuse.
Old Jan 31, 2008 | 12:47 AM
PaulWil's Avatar
Yes, thanks - I was just thinking about that this morning....be a shame to set the car alight so soon after getting it
Old Jan 31, 2008 | 04:41 AM
noizyboyz's Avatar
And make sure the fuse it at the battery end of the cable. Any short between the fuse and the battery will not be protected!
Old Jan 31, 2008 | 08:31 PM
[QUOTE=noizyboyz,Jan 31 2008, 03:41 PM]And make sure the fuse it at the battery end of the cable.
Old Feb 1, 2008 | 11:31 AM
NNervous_R's Avatar
I use CTEX XS3600 - has a wiring harness that you can leave on the battery all the time & just plug into the lead from the charger. When not in use the harness just tucks away by the battery. Works a treat.
s2kcanuck
Mar 8, 2015 09:21 AM
Jstone_ap2
Nov 9, 2013 09:53 PM
liquidgsr
Apr 7, 2013 03:43 PM
sbrodacz
May 1, 2009 07:51 AM
CIVICTOS2000
Aug 17, 2005 01:04 PM
