UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
Annoying when this happens isn't it. Tyre is 6months old a few thousand miles and probably used 2mm of tread. Theaded part of the bolt is about 3mm, I've not yet taken it out but tyre was down to 9psi pumped up for the short trip home but has held pressure since.
Is it repairable?
Should I even bother?
Can I get away with just 1 rather than the pair (Gy Assyms)
Would have been mush happier if it was in a rear as they only have 3-4mm left so are getting towards end of life.
I wouldn't repair it even if they( Kwit Fit etc said it was ok), its in the edge on the shoulder, them little black bits of rubber are sort of important to keeping you safe.
But it is a right pain, and expensive. How you proceed is a bit of a Dilemma isnt it. it happened to me once with 5m left on rears I changed them both.
