Diff Oil
Old Jan 27, 2009 | 11:50 PM
OldDogmeat's Avatar
Default Diff Oil
About to change all oils again and decided to read up again to see if any new info has appeared.
Reading through old threads and there seems to be a lot of conflicting opinions on various aspects of the correct Diff oil for the S's LSD.
This thread questions whether the Motul 300 gear oil is suitable for the S's Diff based on the fact that the Motul 300 bumf states that it isnt suitable for a diff with an LSD (about halfway down the page Shopman throws the question into the mix)
https://www.s2ki.com/forums/index.php?showt...0&#entry9510934
but this thread (near the bottom with MikDys's statement) suggests that a Non-LSD hypoid oil should be used on the S's Diff due to it being clutch-less.
https://www.s2ki.com/forums/index.php?showt...&#entry12363386
I fear taking my Dealers opinions on board as being gospel as there are loads of threads on here with clueless dealers giving incorrect information resulting in damaged cars.
So; What's the score with the S's LSD; Which oil is appropriate? I'm confused.
Old Jan 28, 2009 | 12:17 AM
loftust's Avatar
I used Castrol EPX (75W90??), available from Hellfrauds and did it myself...I don't trust the dealers!
Old Jan 28, 2009 | 12:35 AM
S2000_FUN's Avatar
Lubrication Engineers (LE) is the best i believe. Another option is Motul 90PA
Old Jan 28, 2009 | 01:08 AM
tomkbucks's Avatar
i use Motul 90PA - has been very good , no problems - though i do have a noisey diff.... this was not the cause but did not cure it either.
Old Jan 28, 2009 | 01:09 AM
Nick Graves's Avatar
The Torsen (or Linda as I call her) doesn't shear the oild as much as the C&P and no, there are no clutches.
Any EP-rated 90 viscosity oil ought to do it.
It needs changing frequently though!
Old Jan 28, 2009 | 03:36 AM
Si2k's Avatar
Syntrax would be a decent option too.
Old Jan 28, 2009 | 05:23 AM
m1bjr's Avatar
Agreed, the manual specifies only #90 weight extreme pressure / hypoid gear oil, nothing special.
Old Jan 28, 2009 | 08:42 AM
AquilaEagle's Avatar
Administrator
I use Redline 75w90 always have, diff has 191k on it and going strong
Old Jan 28, 2009 | 10:28 AM
OldDogmeat's Avatar
Can't argue with 191k and no problems and the Yanks seem to really rate the stuff too.
Redline it is then.
Old Jan 28, 2009 | 11:37 PM
OldDogmeat's Avatar
LOL, I bottled it with the Redline when ordering
Ended up deciding to give Motul a try after all the rave reviews I've read about it.
One thing that has really jumped out is the price hike in oils in general since last September when I last bought a load.
I ended up going for this lot which worked out at
s2konroids
Sep 6, 2012 01:40 PM
strar8
May 6, 2010 09:43 AM
HighwayStar
Apr 19, 2010 02:25 PM
DELLROY
Sep 19, 2003 10:39 AM
Porsche518
Aug 14, 2002 01:58 PM
