Dipping Idle
Old Sep 2, 2011 | 03:08 AM
BigDogsWang's Avatar
Default Dipping Idle
When the car is warm, the idle tends to dip to about 3 / 400 rpm momentarily after blipping the throttle or dipping the clutch when braking. It hasn't stalled yet, but it feels like it's going to.
Any suggestions? ECU reset maybe?
Old Sep 2, 2011 | 03:15 AM
gbduo's Avatar
Search for IACV and think that will solve that
Old Sep 2, 2011 | 03:17 AM
Spies's Avatar
Thought it was a common problem. Mine hasn't stalled either, always recovers.
Old Sep 2, 2011 | 03:23 AM
funnily enough I've just been reading about it. Going outside now to remove and clean, will report back
Old Sep 2, 2011 | 03:29 AM
Spies's Avatar
I think ambient temperature has an effect on it too.
Old Sep 2, 2011 | 03:31 AM
veehexx's Avatar
mine is scheduled for tomorrow aswell as a few other bits and pieces. hopefully it'll fix the 2nd gear jolt too. if not, it's my driving
Old Sep 2, 2011 | 03:48 AM
MB's Avatar
MB
Member
See technical FAQ. Can be many things...
Old Sep 2, 2011 | 04:42 AM
by jove, I think that's done it
I couldn't get the rubber pipes off, stuck fast they were, so I loosened the throttle cable and managed to swivel it around and give it a good clean. There is a very small valve in the which you can twist around, it was covered in soot so with cotton buds in hand and a can of WD, it's now sparkling and seems to have done the trick.
Thanks to all.
Old Sep 2, 2011 | 04:50 AM
gbduo's Avatar
Woop! Glad you got it sorted!
Sean_2000
Jun 3, 2013 11:10 PM
TKim103
Mar 19, 2009 10:57 AM
HankookS2K
Oct 1, 2008 08:03 PM
Ouhei
Feb 28, 2008 05:23 PM
VTECAZ
May 28, 2003 06:58 AM
