Does the honda stereo use a standard ISO connector
I've just ordered an alpine 9812 head unit, but on flicking through various posts about installs, they seem to imply I need a different wiring harness. On every other stereo I've installed into a modern car they simply plug straight into the back of the new unit, is this not the case with the s2k (its a 2001 model if it makes any difference). I realise that the dash controls wont work unless I buy the interface, but I did assume that the honda harness is just a standard ISO connector.
The Honda loom is not ISO-compliant and that is why you should buy the KCE adapter (see my sig) so that (a) you can plug the Honda wiring into the Alpine unit; and (b) the adapter also enables you to keep the use of your dashboard fingertip controls.
MCS direct are a popular choice of supplier and Halfords wil also order the adapter in.
you also need to buy an ISO antenna adaptor as well for this head unit.
see this thread https://www.s2ki.com/forums/showthread.php?...threadid=125685
Oh i only saw 1 type - i don't have the packaging anymore but if i remember correctly the male plug on the end of the OEM antenna was too big to fit in the female socket on the alpine.
The adapter i got had what looked like a larger socket than the Alpine socket joined to a small (smaller than on the antenna) male plug with a short (say 5cm) piece of co-ax. Hmmmm not sure that description is of much help...1 of the connectors was at a right-angle (i think it was the one that connected to the Alpine)
Take a look at http://www.incartec.co.uk/Incaraudio1_ante...nna_adapter.pdf
The image on the top left of the page (21-103) looks like what i got from Halfords - but it doesn't tell anything about the size of the socket and plug
hope that is of some help
Simon
Simon
