eBay S2000 BBK
Hi all,
What are your opinions of this BBK on eBay, apparently it uses the CLio 3 RS Brembo Calipers with 350Z discs, looks good to me but would this be a decent upgrade ?
eBay S2000 BBK
Cheers
Si
eBay S2000 BBK
Cheers
Si
Brake bias is going to be severely shifted to the front if you are using that with stock rears.
This is just from a quick google telling me the piston size is 4x40mm on that caliper, feel free to verify if this is indeed correct.
Plenty of heat capability in that rotor but also plenty of weight since it's not a two-piece.
Mostly OEM parts so should be fairly good quality.
