EBC rear pads
Old Jan 7, 2006 | 07:59 AM
VaNisH's Avatar
Default EBC rear pads
just receive them today
but found there is something missing?
as the pic shows
is it normal?
the left one has a little Clip while the right one dot
Old Jan 7, 2006 | 08:14 AM
Trung_EP3CTR's Avatar
Well, where's the pics then?
Old Jan 7, 2006 | 08:38 AM
VaNisH's Avatar
pic add
Old Jan 7, 2006 | 08:39 AM
Bassoctopus's Avatar
Why are you fitting green stuff on the S2000? I've been advised against this many times - they're not up to the job apparently
Old Jan 7, 2006 | 08:41 AM
VaNisH's Avatar
i get them free from a friend
Old Jan 7, 2006 | 08:57 AM
VaNisH's Avatar
any one have experience?
Old Jan 7, 2006 | 03:01 PM
chilled's Avatar
I believe both sides should have the wear indicators (which is what the metal thing is) but I could be wrong. That's what's missing if anything.
Is that fronts or rears showing?
Old Jan 7, 2006 | 05:23 PM
The metal clip is the pad wear indicator and as Chilled mentioned there should be one on each set of pads.
It's still fine to use them with one clip missing as long as you remember to check your brake pads regurely.
From personal experiance Green Stuff pads are total crap but since it's for the rear brakes then it should be ok. I've used Green Stuff for the front brakes and it only lasted 5,000miles and one trackday. The pads started to cook only after a couple of laps.
Old Apr 7, 2006 | 02:26 AM
vadhert's Avatar
I have greenstuff on the back for about 2 months now with EBC grooved disc's also. The brakes work well and do not leave much dust either
mike5im5
Jul 13, 2012 05:00 AM
tbakker
Feb 21, 2011 07:33 AM
FistralG
Jul 14, 2010 10:29 AM
Dum Dum Head
May 13, 2001 02:24 PM
