Ecu Help
Old Jan 31, 2008 | 02:40 PM
  #21
chrisr111's Avatar
Originally Posted by killasystems,Jan 31 2008, 11:17 PM
i dont have a flashing key light?
Is your car JDM or UKDM?
Chris.
Old Jan 31, 2008 | 11:00 PM
  #22
eSeM's Avatar
Originally Posted by Tango Man,Jan 31 2008, 11:11 PM
You will still need the immobilizer key/fob with a Mugen ECU.
Depends on the car.
If the car was a UK suplied car then the chances are it will have the POS alarm installed.
If it is a Euro or a JDM import the chances are that it wont.
killasystems, how old is your car and do you know it's origin.
Old Jan 31, 2008 | 11:15 PM
  #23
Xd's Avatar
Xd
Guys I was talking about the UK model, sorry for not making that clear, I was trying to be non-specific for security.
Old Jan 31, 2008 | 11:34 PM
  #24
syvee's Avatar
autodata say engine control module fault ... sounds like ur having a right pain with this sorry cant help more
Old Jan 31, 2008 | 11:37 PM
  #25
MB's Avatar
MB
Member
The fault code he has, has nowt to do with the ECU being buggered though.
I am still totally confused at why you are battling to try an ECU when you should be looking to find the fault you have.
The logic of having a repeating fault code, so just replace the ECU, isn't the way to go.
Old Jan 31, 2008 | 11:43 PM
  #26
eSeM's Avatar
P1607 - ECM/PCM Internal Circuit Failure
Are you sure?
Old Jan 31, 2008 | 11:56 PM
  #27
MB's Avatar
MB
Member
Ah, ok that is indeed a Honda specific code, I was using a generic list which pointed to air leak / vac solenoid.
Happily admit i'm wrong
What I would say is maybe check the loom though.
I'd also find out the reply to Chris' question on whether the car is a JDm or UK, and if the ECU is JDM or UK.
If it was an immob fault, would it start at all?
Old Feb 1, 2008 | 01:31 AM
  #28
eSeM's Avatar
I can see that you are practicing to become a CO by skim reading the threads .... just like Mike has started doing.
Old Feb 1, 2008 | 01:34 AM
  #29
killasystems's Avatar
the car is a uk car and totally standard if it helps "ecm/pcm internal circuit failure" im advised the ecm/pcm is the ecu right?
Old Feb 1, 2008 | 01:43 AM
  #30
eSeM's Avatar
IIRC The early cars didn't come with the POS Honda UK alarm.
Do you know what sort of alarm you have on the car?
