Ecu problems
Old Jun 27, 2013 | 08:29 AM
Edds2k's Avatar
Default Ecu problems
Hi all. Just asking for a little advice. I've got an early JDM ap1, and somewhere down the line I think a ukdm engine has been dropped in as the engine code is F20C2-****
I think I have a faulty ecu as it won't read my secondary o2 sensor. So I have picked up a UKDM ecu with the key and the transponder. My plan is to fabricate a little loom for the transponder and wire it in with the key selotaped to it. I think I have found the corresponding pins for the immobiliser, I can't however find the pin for the fuel pump relay on my original JDM ecu so I can rewire it to the immobiliser one. If that makes sense. Does anyone know which pin it is, and even if it is possible?
Cheers, Edd
Old Jun 27, 2013 | 11:34 AM
Ultra_Nexus's Avatar
Faulty ECUs are rare. UKDM engines work fine with JDM ECUs (Whereas UKDM ECU with throw a CEL with JDM engine).
I think it's a wiring issue with your secondary 02 sensor.
Old Jun 28, 2013 | 01:18 AM
Edds2k's Avatar
Is the fueling map not different because of the different compression?
All I'm getting is a constant 3 volt reading on the secondary O2 sensor and we have checked the wiring back to the ecu :s
Old Jun 28, 2013 | 02:55 PM
Have you replaced the O2 sensor? Don't worry about the fuelling - I know of a UKDM engine in a JDM car from years ago that is running fine. The UKDM engine has sensors that the JDM doesn't. Infact, You may throw a CEL with the UKDM ECU due to fore mentioned missing sensor wiring.
Old Jun 28, 2013 | 09:50 PM
Joeh's Avatar
My JDM had a F20C2 in it for years
Edds2k
Apr 3, 2013 04:18 AM
Chief Robert
May 26, 2012 05:26 AM
alricl
Nov 20, 2011 04:10 PM
mugen888
Sep 16, 2011 02:30 AM
mog2000
Feb 22, 2007 04:24 PM
