Engine coolant type
Old May 16, 2013 | 11:43 PM
sound_wave's Avatar
Default Engine coolant type
Mornign all,
Right, decided that it's time to change the engine coolant. (Car is an MY05 and i'm not sure it's ever been changed.)
Is there a specific type that is needed, and also how much is needed?
Thanks,
Andy
Old May 17, 2013 | 12:57 AM
ROB1980's Avatar
I used original Honda coolant and needed about 7 litres if I remember, got it from here
http://www.coxmotorparts.co.uk/genui...xed-p-492.html
Old May 17, 2013 | 01:24 AM
TangoVTEC's Avatar
^ What he said.
Have fun with the block drain bolt too......
Old May 17, 2013 | 01:43 AM
ROB1980's Avatar
Originally Posted by TangoVTEC
^ What he said.
I just used the radiator drain tap, didn't bother with the block drain, even on a ramp it looked a pain in the ass
Old May 17, 2013 | 02:24 AM
AlexGJ248's Avatar
Just done mine at Ray's Andy. Only done it because I wanted some nice colourful Samco coolant hoses! I bought two 5 litre bottles of coolant from Hendy Performance.
http://www.hendyperformance.co.uk/pr..._08clag01820_4
Old May 17, 2013 | 02:32 AM
Ultra_Nexus's Avatar
Just get some from halfords. It'll be fine
http://www.halfords.com/webapp/wcs/s...egoryId_255224
Top it up with some distilled water. Jobs a guddun.
Old May 17, 2013 | 06:36 AM
E4RTH WORM JIM's Avatar
Honda type 2 for me
Old May 17, 2013 | 08:31 AM
Stoatmaster's Avatar
Halfords coolant used to make my Mitsubishi's coolant system go furry, so I switched back to L250 (Which was Nissan I think). I believe this was due to the different inhibitors they use that reacted, which is worse than normal with aluminium blocks. Not sure if the pink halfords stuff is the same blend as what you are currently running.
Always try to use the same coolant blend unless you are fully flushing the system, or they can react. A full reverse flush should do the job.
Old May 17, 2013 | 11:01 AM
sound_wave's Avatar
A full reverse flush? Sounds painful!!
speakeasy2009
Jul 31, 2017 10:44 PM
scuderiax8
Dec 31, 2011 06:08 AM
pputkowski
Oct 20, 2008 11:31 AM
cmflex84
Jun 27, 2006 08:40 AM
Zeemz
Dec 22, 2005 09:41 AM
