engine cuttig out
Old Aug 30, 2008 | 01:06 PM
tagon42's Avatar
Default engine cuttig out
my engine is cutting out at low revs when i pull up i have to rev to stop stalling i use ron 97 fuel
Old Aug 30, 2008 | 01:16 PM
lukedon's Avatar
clean your idle air control valve
https://www.s2ki.com/forums/index.php?showt...&#entry11447316
Old Aug 31, 2008 | 01:01 AM
MB's Avatar
MB
Member
Hi tagon, have a read of the thread linked in my signature below.
I'd tend to think you have popped a vacuum hose somewhere (or an air leak) or a lambda sensor fault.
Has the car started using more fuel?
Does it always stall when you pull up?
Old Aug 31, 2008 | 02:08 AM
goldingt's Avatar
I've got the same problem so I'll be trying the IAC clean today if the rain stops. I've been running with the air box lid off these last few weeks. Can this have any effect?
Also do I need to take the MAP off to give it a whack? I ask as I'm struggling with one of the screws which won't budge (it's now a little worn despite my efforts not to round the head )
Tim
jym89709
Mar 8, 2011 10:28 AM
Spec_Ops2087
Jun 13, 2010 11:32 PM
Ks320
Feb 7, 2009 06:49 PM
supahman04
Mar 17, 2008 07:38 AM
jinjer
May 26, 2006 04:19 PM
