Engine cutting out when cold
Originally Posted by oxhouser' date='Dec 28 2008, 08:07 PM
Ok
Just finished a 260 mile trip and it's cutting out even when warm
I think the AEM FIC only works on boost so should effect
Idle
What controls idle and where are the components located?
Idle
https://www.s2ki.com/forums/index.php?showt...&#entry11797776
^ sorry i seem to have deleted the pics from my gallery
Ah, is your AEM the piggyback one?
If so you are correct that it only works on WOT / boost. Also makes it easier to diagnose.
Given it's cutting out at cold and warm, that makes it a bit easier too.
The main things which can affect idle are:
Vac leak
Lambda sensor shot (quite a common one and will be a bit hesitant off boost)
MAP
Other tips in the link in my signature.
Vac leak
MAP
Just a quick update
Cleaned the ICV and map sensor put it all back together
And it runs like a dream, it would have been an easy job
But for having to use the antiques my dad calls tools
whitworth!! BA!
Thanks for the help
whitworth!! BA!
Thanks for the help
ReDevil
Jun 18, 2003 11:38 AM
bluegene
Sep 8, 2002 02:24 PM
