Which engine oil to use?
Hi
I know there are probably posts about engine oils already, but the new forum search is pretty rubbish.
Just wondering which engine oil to use ?
Can you mix different oils? I.e topping up with different oil
Any info will be appreciated
This one, ignore the diesel bit it makes no difference.
http://www.opieoils.co.uk/p-719-cast...ngine-oil.aspx
And you can get it from Halfords.
Don't use 0w it will feck your timing chain tensioner.
I found the answer in 3 clicks and typing in the word "oil" Works perfectly.
Maybe we need a how to use the search topic.
The key is clicking on the cog icon, then you get the full search options.
Type in "oil" in the top box.
Then select "forums" although it should already be selected.
Then click UK community.
And away you go.
And away you go.
