EPS Light on - No Power Steering - No fault code (DTC)
Old Mar 19, 2011 | 09:33 AM
nicholasbartleet's Avatar
Default EPS Light on - No Power Steering - No fault code (DTC)
Hi guys,
I started my car a while ago after standing for a few months unused and the EPS light came on. The power steering has gone, but strangely there is no fault code. Had anyone had anything like this happen t them before?
I have removed all the fuzes with no luck. I have disconnected the battery several times with no luck. I have driven the car for a while and then restarted the car with no luck. Scratching my head now with very few ideas because of the lack of a DTC and i don't just want to start replacing parts.
Old Mar 19, 2011 | 03:13 PM
Stratocaster's Avatar
I wonder if the connector to the EPS unit under the hood are not corroded. I would remove each of tthem and spray them with some contact cleaner and contact grease. Then reseat them and test again.
Old Mar 19, 2011 | 10:22 PM
AliasMrJones's Avatar
I had something similar, but not exactly the same. EPS light came on, no power steering. I turned the car off and then tried to start - no starter either. All the power in the car seemed to be fine and no dimming when I pushed the start button. Turned out one of the 2 cables coming off the positive battery terminal was loose. I reconnected it and everything went back to normal.
Old Mar 20, 2011 | 05:36 AM
Thunder-rush's Avatar
If you already did the EPS calibration sequence and tried every fuse related then do what stratocaster recomended, clean the conectors in the eps controller and the 2 in the eps steering rack. I had the same problem No Eps it only worked if I turn the steering to almost lock position creating load to the steering rack and at the same time pressing the start button and starting the car. I later found out the problem was the steering angle sensor, went to ebay bought a used low miles steering rack for $250 once instaled Eps light went off and power stering worked.
Heres the link for the Eps calibration procedure in case you need it.
http://forum.aempower.com/forum/inde...c,10043.0.html
Old Mar 20, 2011 | 05:55 AM
Sideways's Avatar
Is the car stock or has it been modified?
Old Mar 20, 2011 | 06:34 AM
Thanks everyone.
I just checked all the connectors to the eps and they were all immaculate. I popped them back and no luck. The battery terminal connections are all fine too.
I haven't done the eps calibration sequence so will give that a go next. Thanks.
The car is heavily modified, but that relates more to the suspension, wheels, body modifications and interior. The engine is stock as is the ems.
Old Mar 20, 2011 | 06:57 AM
Sideways's Avatar
Originally Posted by nicholasbartleet
Thanks everyone.
Gears and a yellow box?
Old Mar 20, 2011 | 07:12 AM
Sorry I don't understand the question?
I have been reading up about the Torque sensor neutral position relearn, and i distincly remember shorting pin 4 and 9 before and blowing a fuze. I later found out that the obdii port in the uk is very different to the US versions and i don't think we have the option to short those pins in the UK. I was using pins 4 and 9 before to try and bring up blink codes, (FYI: we don't have the option of blink codes in the UK)
plizzat
Aug 3, 2017 11:15 AM
speedzx
Feb 28, 2017 11:27 AM
theoldguy
May 24, 2013 02:00 AM
667
Dec 18, 2006 08:23 AM
zking786
Aug 6, 2005 06:28 PM
