Fault codes thrown - ScanGuauge
Hi All
So thought I would check my codes again after 3 months of ownership and the following codes keep appearing:
-C1500-
Transfer case contact plate B encoder circuit failure
-C1555-
The (C) in C1555 means (C)hassis (P)=Powertrain/Engine, (T)=Transmission.
C1555 = EMPS ECU Malfunction
(Electric Motor Power Steering (EMPS) Electronic Control Unit (ECU))
-P0007-
Generic OBD Error Code Details for P0007
Fuel Shutoff Valve "A" Control Circuit High
What does this mean?
OBD Code P0007refers to
Fuel Shutoff Valve A Control Circuit High is the generic definition for the P0007; however your vehicle's manufacturer may have a different definition for the P0007 code.
Symptoms
Possible sumptoms of OBD code P0007
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0007
Possible Solutions
The P0007 is an OBDII generic code, but almost none of the vehicle manufactures use it. If you are getting this code, make sure you are using the correct OBDII code scanner for your vehicle's make and model.
-P0005-
Generic OBD Error Code Details for P0005
Fuel Shutoff Valve "A" Control Circuit/Open
OBD Code P0005refers to
Fuel Shutoff Valve A Control Circuit/Open is the generic definition for the P0005; however your vehicle's manufacturer may have a different definition for the P0005 code.
Symptoms
Possible sumptoms of OBD code P0005
Causes
Possible causes of OBD code P0005
Possible Solutions
The P0005 is an OBDII generic code, but almost none of the vehicle manufactures use it. If you are getting this code, make sure you are using the correct OBDII code scanner for your vehicle's make and model.
Cant quite get definitive answers as to what these codes mean, any ideas?
Cheers
Jason
-C1500-
-C1555-
-P0007-
Symptoms
Causes
Possible Solutions
-P0005-
Symptoms
Causes
Possible Solutions
Cheers
Jason
http://www.superhonda.com/forum/f94/codes-all-231338/
http://honda-tech.com/showthread.php?t=1490107
I've never heard of a "C" code relating to the S2000 (or Honda) maybe you need to try a different reader?
GreenmanS2000
07-29-2013 12:27 AM
