A few running issues
Old Apr 3, 2013 | 02:04 PM
RichGS2k's Avatar
Default A few running issues
So after fitting a Greddy turbo kit and getting it all mapped up a few months ago, I have run it for just over 1000 miles.
Over these miles I have observed a few issues:
it would occasionally loosen a few of the spark plugs (different ones each time, although tonight they were all tight)
there is a random misfire on town driving (sometimes worse sometimes not at all) I have used injector cleaner and that hasn't solved anything
tonight doing the spark plug check I noticed a mild amount of oil in cylinder 3 and a heavy amount in cylinder 4
it seems to burn oil when it is running for prolonged periods of time
and finally it is repeatedly distorting/bending the EGR valve blanking plate, so far it has killed 2-3mm thick aluminium and a 1.5mm thick stainless steel plate
I am guessing a few of these have the same root cause, but does anyone have any points for me to start looking at?
Old Apr 3, 2013 | 02:17 PM
unclefester's Avatar
Plug gaskets in the rocker cover is one option for oil in the plug holes but if its in the cylinders themselves ... that suggests breather issues - are you sure the ventilation of the crank case is working properly?
I am sure i saw something about pressurising the inlet with leaking boost causing problems but i'm NO expert!
Moddiction
Oct 31, 2022 08:31 AM
Madkows
Aug 20, 2020 12:06 PM
joshf47
Jun 18, 2014 11:50 PM
s2k_bmich510
Jan 30, 2008 05:11 PM
wasu55
Sep 25, 2003 08:40 PM
