spark plugs were lean and had oil
Old Sep 25, 2003 | 02:44 AM
wasu55's Avatar
Default spark plugs were lean and had oil
i have an 01 and i bought it with 10k miles on it. i changed my spark plugs today, for the first time (30K) miles. the first thing i noticed was how chalky they were. all i have done to my car is a spugen exhaust. does that make me run that much leaner? and the second thing i noticed was oil residue on the threads of the spark plugs. the one closest to the driver, had a good amount of oil. ONLY on the threads though. is this common? what could be the problem? thank you for any help you can give me.
Old Sep 25, 2003 | 05:18 AM
marcucci's Avatar
It shouldn't make the car run leaner. Honda plugs normally look grayish- that is normal. The car runs relatively lean at part throttle- you will only see a dark plug if you spend a lot of time WOT.
Oil on the threads usually means your valve cover gasket (the donuts) is leaking.
Old Sep 25, 2003 | 07:45 AM
fly_S2K's Avatar
Try regapping your plugs to factory specs.
Old Sep 25, 2003 | 09:12 AM
wasu55's Avatar
thanks fly_S2k and marcucci. i appreciate it
Old Sep 25, 2003 | 08:40 PM
RazorV3's Avatar
your exhaust system shouldn't have anything to do with your air/fuel ratio. this system comes into play after combustion has already taken place. the only regular bolton that can affect your air/fuel ratio is an aftermarket intake. since its now offering a higher velcoity of air, the car will run leaner(more air than fuel).
joshf47
Jun 18, 2014 11:50 PM
s2k_bmich510
Jan 30, 2008 05:11 PM
Kenpo_S2000
Jan 13, 2006 04:27 PM
LouS2K
Jun 27, 2002 10:10 PM
fish
Aug 6, 2001 11:59 AM
