Flywheels...
Just wondering how much of a difference a lightened flywheel would make to acceleration? I was looking around and apparently the standard flywheel is 15lbs or 6.8kg, the toda flywheel is 3 kg lighter.
How much of a difference would this make to the drive ability of the car? Would it be very noticeable? And combining this with a 4.44 final drive, would this be a good investment?
I've just had a 4.7Kg/10.4 lb RPC flywheel fitted, I didn't time 0-62 with a before and after but I'd say you can feel the torques reaching the diff/rear a bit more and it feels revvier.
I don't think there are any downsides - idle is fine, pulling away is fine - you don't need higher revs than with standard, so going even lighter with the Toda to 3.8Kg should be fine too.
A good mod for NA I think, the only pain would be getting the 'box out, so something to do when you clutch is on its way out I reckon.
It'll make no difference to the acceleration. I could get all silly and pull out some angular velocity/acceleration calcs and prove that the net affect is about 1.5bhp or something else that is completely trivial.
What it does do is aid the driveability of the engine.
Corleone
May 5, 2004 01:27 AM
