Front Spoilers Cont'd
Thanks for all the input on the previous front spoiler thread. I have decided to go for the oem one. Graham at Ewell Honda is doing me a good deal, following the group buy that was done.
For those of you that have fiited them. How easy is it?
Any fitting advice would be appreciated.
Cheers
Cheers
Fairly easy all the bolts and holes are already on the car. I would suggest that if you have some car ramps then it is easiers - but not necessary as I did mine without.
The box is massive and when opened creates a great mat to place under the car for you to lie on and for the spolier to fall against without worry of scratching it.
Just take your time and when finshed stand back from a distance and check that is level - tighten for the final time and admire.
I clayed the area covered by the spoiler washed, polished and put plenty of wax on before I fitted it. The best change that I hae made to mine and will change the front quite a lot and even if you have seen other OEM spoilers on other S's it is different when its on your own.
Enjoy :tumbup:
Enjoy :tumbup:
