Garage Width?
Old Apr 14, 2006 | 03:58 AM
fluffyninja's Avatar
Probably a good idea to set the width as that of the S plus the full extension of the door opened as a minimum otherwise you end up with the above pictures
One little trick my gran used to use to set the correct distance to park the car in to the garage was to hang a plumb-line from the roof that would touch the windscreen at the correct distance in (driving forward) Could maybe try something similar instead of the drive in until I feel resistance method
Old Apr 14, 2006 | 04:16 AM
ade73's Avatar
Normal single garages are just under 8foot wide. Park close to the passenger side and there should be enough room to half open the drivers door to get out. Use a parking mate on the floor and wall.
Old Apr 14, 2006 | 04:32 AM
Deathside's Avatar
Right then - Here's what I've got so far:
Width of S2000 - 68.9inch = 1.75m
Proposed internal width of my garage 2.7m (8 ft 10 inches)
What I can't find at the moment is a figure for width of an S with one door fully open??
Old Apr 14, 2006 | 04:51 AM
NNervous_R's Avatar
Just measured: open door edge is about 950mm from side of car when fully open
Old Apr 14, 2006 | 05:02 AM
Bandit_287's Avatar
Dont worry if you scrape the side of that grey S on the garage wall it wont show as the primer is the same colour as the topcoat
Old Apr 14, 2006 | 05:03 AM
Deathside's Avatar
Thanks that really useful - Looks like the door won't fully open - But should be wide enough to get in and out without a struggle
Old Apr 14, 2006 | 05:16 AM
aldfort's Avatar
If you can make the garage 9 ft 6 ins inside it will make all the difference is only one brick more. does not change the sive of door you use and you can bias the space to one side relative to the door.
Old Apr 14, 2006 | 05:25 AM
Amuse Boy's Avatar
I had a garage built and the dimensions were 11.5ft wide and 19ft+ in length. If I park the car in the middle, I can open both doors to the first click - but if I park to one side I can open 1 door fully.
Old Apr 14, 2006 | 05:35 AM
RichUK's Avatar
I see some dust on your carpet AB!
Old Apr 14, 2006 | 05:43 AM
Badger's Avatar
That's no garage...it's a space sta...no wait..
