Geo help please
Old Mar 24, 2011 | 06:36 AM
mobile chicane's Avatar
Default Geo help please
Hi all sorry I havent been on here for a while work and other things were getting in the way of my fun.
Anyway I've just blagged 2 free days off ( today and tomorow ), I've fitted the new rear n/s wishbone to my 1999 s2k and now it needs a geo.
I live in thatcham in berkshire( 40 miles west of london ), TGM who I usualy use are booked solid so is there anywhere else I could go to get it done ?
I'm also after the standard smooth road geo set up data for a 1999 s2k with standard 16 inch wheels.
ta in advance _
Old Mar 24, 2011 | 06:42 AM
hazzaman's Avatar
you could try tony @ wheels in motion.
About 45 miles from you.
33 Chess Business Park
Moor Road
Chesham
Buckinghamshire HP5 1SD
http://www.wheels-inmotion.co.uk
veehexx's Avatar
if it's just to get it in tolerance while you get a proper job done (or to get it set at values you want), try your local tyre shop.
Old Mar 24, 2011 | 06:54 AM
Cheers guys, I've found somwhere in swindon that seem to know what there doing, what I'm after now its the stock and smooth road ( stable at high speed) settings.
the swindon place want £80 which sounds reasonable for the work, they do have the standatd values on file I just want to lookm at those and the smooth road set up and see the difrence before I decide.
Old Mar 24, 2011 | 07:01 AM
lovegroova's Avatar
They should have standard settings, but the "skill" is getting things close all round.
For example, the standard rear camber setting is -0°30' [-1°30' ] +0°30' which means that anywhere between -1° and -2° is ok. you need to make sure that whoever sets it up sets everything up symmetrically.
Old Mar 24, 2011 | 08:09 AM
Nick Graves's Avatar
Equal & opposite is important.
You can 'fine-tune' it once you've got used to the car & decide what you prefer. I like less toe-in & less caster for quick turn-in & throttle-adjustability.
Others are happier with a more 'directionally stable' set-up.
If you're a cornering nut, 16"ers could benefit from an extra 1/4 or even 1/2 degree of camber.
Old Mar 24, 2011 | 08:46 AM
veehexx's Avatar
ask for a print-off. they they try to pull the "but it's within tolerance" game, then it's on par with different tyres on the same axle; you have to have the same either side!
£80 is cheaper than my local (they charge per adjustment). i think i got £120 bill at my local with all but 1 or 2 adjustments.
Old Mar 24, 2011 | 11:21 AM
hammyS2's Avatar
If you don't mind travelling a little there is this place in Essex.
All new equipment (Hawk eye) and top guys who know their stuff. Plus you can see all the measurements on screen as they do the work!!
http://www.skidmarquesltd.com/
Oh - and competitive pricing!!
Some great roads back home as well!!!
Old Mar 30, 2011 | 12:22 PM
Right update time.
I had the geo done at imperial tyres in swindon.
The bloke doing it knew his stuff and it took him about 3/4 of an hour, I had made sure all adjusters were free before hand.
The car now handles mutch better.
The bigest difrence in the symetery after set up was in the rear camber lhs being 1.25 and the rhs being 1.32 well within the + - 0.3
nice place and had no problems letting me have a look around under the car when it was on the ramp.
willf
Jun 22, 2012 11:02 PM
Pelidan
Jul 11, 2010 11:57 PM
jimmyb1978
Jul 24, 2009 02:05 PM
Fatbloke
Jan 4, 2009 11:05 PM
mobile chicane
Sep 14, 2008 05:10 AM
