which grease for inner cv joint
hello,
just cleaning out and repacking my inner cv joints with some grease, but what type of grease should I use? is it the normal grey cv joint stuff, or did Honda use something else?
Hi I used this from opie oils
Red Line CV-2 Grease is a high-performance synthetic grease with red moly, designed to withstand the extreme temperatures and pressures which occur in high-performance wheel bearings and CV-joints. 150 - 160 grams in each
The factory band clamps on this car are the most superior design. They can, and SHOULD, be re-used. They could litterally be re-used hundreds of times. A simple pair of pliers easily releases them.
Grip the small cup and the bar opposite, squeeze together and it will pop apart.
Santenay
Mar 30, 2015 03:01 PM
