headlight bulb replacement
Old Dec 30, 2013 | 12:24 PM
drives's Avatar
Checked the fuses- they're fine. I was just going to swap the ballasts over to check to see if this is the problem which i presume will work as they're the same both sides i presume? Anyway this is turning into a mission, set about removing the front bumper- simple enough in theory but the stupid screws at the top weren't budging. In the end after all day spent trying to remove them i had to buy an angle grinder to get them off and then use water pump pliers to get out the remaining stumps. Will have to wait until new years day to do a bit more tinkering and swap them over..
Old Dec 30, 2013 | 12:27 PM
drives's Avatar
Originally Posted by richmc
Try swaping over the relays and fuses first, after that theres no safe way of testing the ballast except for getting someone else to do it, an auto electrician is the best bet as you are in a hurry.
Good luck.
rich when you say relays which bits so you mean? Is this the wires going from ballast to bulb?
Old Dec 30, 2013 | 05:23 PM
noodels's Avatar
Under bonnet main fuse box number 1&2 are headlights relays the 3rd is horn,near fuses 15-22 these are close to the relays you need to check. 12,13,14 relays are fans ect
so swap out them relays and recheck
Old Dec 30, 2013 | 11:33 PM
richmc's Avatar
What he said.
Old Dec 31, 2013 | 01:08 AM
noodels's Avatar
ps..
Also some ballast parts in the for sales £30.
All the fuse/relays ect are in the handbook
Old Dec 31, 2013 | 08:42 AM
drives's Avatar
most helpful thank you. Will swap them over tomorrow..
Old Jan 1, 2014 | 02:38 AM
drives's Avatar
Right I've located the problem, would really appreciate a bit more help...
when I removed the ballast, water literally started pouring out. Basically water has been getting into the headlight and sitting on top of it, rusting away the connections. So...I'm gonna hunt the classifieds now for a second hand unit. My questions now are:
1. Can i run my car and use the sidelights safely without putting the old ballast back on for a few days whilst I get the replacement part i.e. What do i do with the cables that run to it? Can I just wrap them in insulating tape and secure them to something, would this be okay? Or just remove the fuse so no power is going to it- would this work?
2. If anyone can give me some pointers on where water/condensation commonly gets into the headlight units that would be great, just to give me some idea of where to look. Ive only got internet on my phone at the mo which is making searching on here a little tricky.
Old Jan 3, 2014 | 12:27 AM
richmc's Avatar
1) Given the voltages involved much safer without it if there's water around, but obviously not legal if you are unlucky enough to get pulled.
2) someone might have had the headlight cluster out to clean it and broken the seal, I've seen a thread on rear lights there must be something on headlights.
Will have a search and post up if I find anything.
Old Jan 3, 2014 | 12:34 AM
richmc's Avatar
Had a look there are a few threads from searching "headlamp condensation". they all say take the lamp out remove the bulb holders, use a hairdryer to clear out moisture and use clear silicone to seal any gaps you may find.
Have a look on ebay as you have yours out you can see what fitting it has and you are going to need one with the wiring I got one from HIDs direct but only one screw lined up so I used cable ties to hold it firmly in place, bit of a fag but it worked.
This is what I got-
http://www.ebay.co.uk/itm/MITSUBISHI...item565b5f544f
Old Jan 3, 2014 | 12:42 AM
BenRNBP's Avatar
The £30 ballasts in the Fore Sale section are facelift - I'm guessing from your sig you are pre-facelift.
Leaky headlights seems to be a fairly common issue - the solution is to bake the glue to loosen it around the lens then re-seal. TBH I think I'd try and skip the baking part and run some additional sealant around where the seal line for the lens/casing is. There's a guide on Ricks for taking the headlight lens off that might help http://www.ricks2k.com/info/instructions/diffuser.pdf
monjebricks
Feb 5, 2015 09:23 AM
Quoi?
Jul 27, 2011 10:42 AM
andrewcfm
Aug 16, 2006 01:09 PM
AquilaEagle
Apr 1, 2006 07:29 AM
enjoikr3w
Jan 27, 2006 05:21 PM
