Headlight / Bumper gap alignment
Old Mar 16, 2012 | 09:52 AM
samg1988's Avatar
Default Headlight / Bumper gap alignment
Just got my car back from the body shop after getting the front end resprayed for stone chips. Paintwork is brilliant, but I noticed the gaps aren't quite right on the head lamps/bumper.
The guy said if theres any issues I can just take it back, but this wont be until Monday. If it's easy enough to adjust I'd be as well doing it myself because I'll be toying around with it anyway.
Has anyone done this before?
Cheers
Old Mar 16, 2012 | 11:21 AM
Chad!'s Avatar
A photo might help people to advise you better?
Chad.
Old Mar 16, 2012 | 11:52 AM
GavB's Avatar
There is some adjustment on the two brackets that bolt inside the bonnet, right by the headlights. They are L shaped brackets. There is also some play in the bracket holes anyway and I usually find I need to lean on the bumper a bit with my knee before nipping up the bolts and screws. You will need to loosen the screws that run along the bumper under the bonnet too to allow movement. Essentially undue all the under bonnet connection, and even the two screws in the wheel arch, reposition and tighten up.
Old Mar 16, 2012 | 02:25 PM
samg1988's Avatar
Thanks Gav I'll give that a go.
SheffieldSam
Oct 27, 2015 10:25 AM
kw_21
Apr 15, 2013 06:20 AM
nick300zx
Apr 5, 2013 01:26 PM
s2000gb
Jun 25, 2009 07:40 AM
Mok
Aug 18, 2006 06:54 PM
