Help
how do you get the spark plug tube seal out of the rocker cover, im in the middle of re furbishing my rocker and have all new seals but the old ones are stuck good and proper
any tips
any tips
done it, what i ever did before i had a dremel i dont know.
ground the steel support ring away unti it was weak enough to bend in
thanks for the help, thought i was doing something wrong as the manual says put the seals on top of the tubes and put the cover on, i cant see that working with the tight fit these are
steve did you fit the new ones back in the cover before re installing?
CynicG
Feb 14, 2017 02:47 AM
