Help!
well tonight I have tried to remove the stereo to try and use the cd changer I have. Sadly this can't work as the changer has a round plug, but the head unit has a square socket.....
Anyway, I tried to refit the flap/air vents and initially it looked ok but didn't sit right at the bottom. The clips were slightly bent so realigned them, but still no joy. So is there a knack of refitting the stereo surround so it sits as it left the factory?
Thanks.
Thanks.
I had this.
The nack is that the bottom clips are bending downwards and missing the holes in the dash.
I bent them up a bit before refitting, and ended up having to get a slim screwdriver down the side to push them up so the click into their holes.
The satisfaction when they pop in place is nice
Originally Posted by chrisr111,Jul 9 2010, 09:29 PM
I found it easier to remove the gear lever surround/centre trim.
Chris.
Chris.
To remove fingers under the edges and lift up working along it's length.
revolution
Jan 12, 2008 02:55 PM
kmunro2424
Aug 23, 2002 01:46 PM
