Help Needed (glue!)
Old Jun 10, 2003 | 04:21 AM
SNAPPER's Avatar
Default Help Needed (glue!)
I went out to car parked on the drive to find that the self adhesive velcro pad that i use to secure the bell 550 has melted on the dash
I have removed said pad & most of the glue but still have a slightly sticky glue patch @ 5 sq inches. I tried wet soapy cloths & isopropyl alcohol
any ideas
will be much appreciated
thanks
warren
Old Jun 10, 2003 | 04:24 AM
M@verick's Avatar
Snapper the exact same thing has happened to me yesterday. I found that if you leave the glue patch to get hot in the sun again, then peel it off whilst gooey it comes away like silicone. It will also stick to itself so once you have a ball of the stuff you have removed, use this to remove the rest (as you would with blue tack)
Its a sticky orrible business but it seemed to work.
R.
Old Jun 10, 2003 | 04:26 AM
wadswoaj's Avatar
Another thing to try is very thin oil...... like Eucylyptus or Albas oil...... these will usually shift nasty sticky messes and leave the car smelling nice to boot!
Old Jun 10, 2003 | 04:33 AM
ahurst's Avatar
with Wad, thin oils are great at this stuff with no lasting damage
Old Jun 10, 2003 | 04:40 AM
samuelhon's Avatar
Hair dryer
Old Jun 10, 2003 | 04:56 AM
SNAPPER's Avatar
Thanks for the advice. I remembered i used WD40 to remove the honda badges so I tried that & it worked a treat. mini crisis over
thanks
warren
Old Jun 10, 2003 | 07:59 AM
wedgemorgan's Avatar
I found a glue mark (epoxy resin?) on the black plastic trim just under my window. I was advised to use nail polish remover to get it off. It removed the glue with no obvious side-effects (e.g. discolouration or changes to the finish). Try it on a hidden part first.
Wyatt
austincrx
Oct 14, 2014 08:27 AM
crispyshark
Oct 18, 2011 07:07 AM
robertjr314
Jun 9, 2011 04:39 PM
slikster
Oct 18, 2008 09:08 AM
VR WHAT
Nov 10, 2004 04:27 AM
