Help Required
Hi All
I am trying to find a wire on the S2000. On a normal car it would be the impulse wire that runs between negative side of the ignition coil and the rev counter.
As the S has not got an ignition coil as such, and the rev counter is digital I
Well I think I can help you then!
I have just fitted a Modifry DCI for the dash controls of the stereo, it needs a speed signal for the speed sensitive volume control.
Full details here!
http://www.modifry.com/products/dci/IR%20D...20Operation.pdf
BTW if you cut this wire and use the end NOT connected to the box of tricks for you speed sensing ie do not splice in the new wire. You get a free mod. Roof down with the handbrake on one click! ie on the move!
Full details here!
Hi Mike
That will do the job for me,
I think I will do the roof down mod at the same time, as having to put the handbrake on full every time I try to raise the hood does annoy me just a bit.
Rog
Rog
Originally Posted by Tomcat,May 21 2006, 05:55 PM
Hi Mike
Rog
Rog
RWIRSING371
Jun 23, 2002 04:16 PM
