How long does the clutch last?
Old May 5, 2002 | 09:23 AM
wadswoaj's Avatar
Default How long does the clutch last?
Seems like lots of you have had to replace the clutch...... how long should I expect it to last?
Has anyone managed to avoid having to replace the clutch?
Old May 5, 2002 | 09:56 AM
S2000RJ's Avatar
I think you will find most clutches have been replaced to cure the noise or gear selection problems. There was a problem with weak springs in the clutch plate, which caused a rattle. This is supposedly fixed with the recent -055 version of the clutch. It seems that Honda will replace the clutch for anyone who complains about the noise. The -055 clutch is a very recent development, so depending on build dates, new cars may still have the -054. IMHO it is too soon to tell if the -055 has actually fixed the design problem.
When Honda changes a gearbox because of selection problems, the clutch is also replaced at the same time.
Basically Honda screwed up big time on the clutch and gearbox, so they will continue to replace them on a regular basis, until they overcome the design and manufacturing problems.
Old May 13, 2002 | 08:19 AM
MW1's Avatar
MW1
My Car is a month old will it have the new version of the clutch?? how do you tell?
Old May 13, 2002 | 11:58 AM
S2000RJ's Avatar
[QUOTE]Originally posted by MW1
[B]My Car is a month old will it have the new version of the clutch??
Old May 13, 2002 | 12:31 PM
steve_the_greek's Avatar
Old May 13, 2002 | 01:59 PM
S2000RJ's Avatar
Originally posted by steve_the_greek
It's very likely to have the new clutch. Just in case, though, you can diagnose it thus:
Drive along in second/third, then when the revs get to about 4500 RPM, come right off the accelerator. Let the car slow to 3000RPM. If you have the duff clutch, you will hear a resonance that sounds a bit like a heat shield or exhaust buzzing/rattling as the car slows.
At one month old, I would be surprised if the rattle had started. IMHO there is a difference between having the new clutch and not having the rattle.
Old May 14, 2002 | 12:30 AM
MW1's Avatar
MW1
Thanks for the answers I will keep listening for the problem.
skyler2k
Mar 11, 2011 05:55 PM
Suits
Mar 7, 2010 02:11 AM
Spacedog
Mar 22, 2008 05:03 AM
gpchaz151
May 4, 2007 08:37 AM
Bob Moss
Oct 27, 2003 07:50 AM
