Hum/slight vibration
trouble is i dont have access to ramp to look! tonight i think i will get the car jacked up, and check for play in the wheel, and swap my front wheels around to see if it changes/goes to the other side of the car.
You may be able to see from looking in the engine bay with a torch.
Attachment 180167
From this thread:
https://www.s2ki.com/s2000/topic/112...eering-column/
That was mine before when it was touching when turning left.
Attachment 180167
From this thread:
Ok so at the weekend i got the car on jacks and looked for play in either of the front wheels, their was none that i could tell, i then tried to spin each one, passenger one span fairly easily, but drivers side not so much, i got the caliper off and then tried to spin the hub and it span a lot easier with no noise, i noticed on of the pads had a indent where it looked as if the disk had been rubbing or catching more than on the rest of the pad.
What could cause this? sticky piston/carrier? i seem to have good breaking performance, and car does not pull to one side or anything like that, also the wheel does not feel any warmer than any other after a 10mile drive, going to clean up the brakes with some brake cleaner and clean the carrier pins and re-lube, but im unsure what to use re-lube the pins, preferably something available from Halfords?
Originally Posted by Define198' timestamp='1431594871' post='23612435
[quote name='S2KIP' timestamp='1431594556' post='23612431']
When the noise happens, do you feel it through the steering wheel at all?
Mine did it but when turning left, Performance AUtoworks put a shim on the passenger side engine mount to move it a few mm which so far seems to have cured it.
[/quote]
In the 7 years I've owned S2000's, all of which have been lowered significantly I have never heard of this problem nor have I ever read another post on the forum about it either. Most people do use rack spacers though so that could make a difference?
I use Red Rubber grease on the sliders, it does not perish the seals and stays viscous.
Copper grease hardens after a while and can cause the sliders to stick.
BTW there is a classic and sports car meet at the Lock keepers 2nd Wednesday of each month, 6pm ish start, all kinds of stuff turns up!
Lee
