invidia test pipe
I have an invidia 70mm with the cel fix, it works perfectly... No light at all... I also have HKS manifold and Miltek exhaust.
Buy the 70mm the s2000 wants to breath better... The 70mm won't hurt it at all and if you decide to pop on a new exhaust or manifold you won't need to buy another decat pipe... The 60mm could be a restriction in future...
Spacer??? New ring gasket - yes.
My pipe bolted straight on, plugged in the sensor... disconnected the battery, have a coffee, reconnect battery, enjoy a normal drive for 20mins or so... Job done. Retighten bolts if needed...
Blox came with pipe wasn't much more. Not sure how much now but got a.good deal I think it was tarmac sports I got it though. The spacers are not always needed as the pipe has the honeycomb structure welded in so it might be ok without the spacer. I got the spacer just to be sure really. Some cars are more sensitive than others
Thanks for the help people very much appreciated. Last question has anyone used these guys
http://hondaperformancepartswarehouse.co.uk
They seem to be the cheapest place I ve found for the pipe and spacer.
veilside_s2k
Mar 20, 2008 04:35 PM
