Killing the Headlamp Washers
Old 11-10-2002, 03:31 PM
Mans Best's Avatar
Default Killing the Headlamp Washers
This may sound like a stupid question, but I can't tell which fuse to remove to prevent the headlamp washers from working.
Does anyone know - I think one or two have already done this,
Thanks
Old 11-10-2002, 11:26 PM
Frenchie's Avatar
Open up the bonnet. Look up by the windscreen on the passenger side; there's a black box about 6" x 3" with its top just below the level of the wing, between the battery and the wing.
Squeeze the ends of the box to free the clips and lift off the top. In the box, towards the front, is a 20 amp and a 30 amp fuse
Pull the 30 amp fuse out and store it in the empty space at the opposite end of the box.
Replace the lid - job's done!
Pete
Old 11-11-2002, 02:37 PM
Mans Best's Avatar
Thanks, Pete
Old 11-12-2002, 07:38 AM
BlueScream's Avatar
These are pics from a Swiss LHD car!
Pull the pink (30A) fuse and press it in the empty space next to the old position.
Source: http://www.s2ki.ch/perso/swiss2ki/
Old 11-12-2002, 07:42 AM
Frisky's Avatar
Or do what I suspect one of the previous owners of my car did and simply pull the plug off the back of the button!
- Frisky.
Old 11-12-2002, 01:17 PM
euan's Avatar
Would you go the whole hog and remove the headlamp washer units from the front bumper altogether?
I found a site the other day where some german "Markus" had done this, filled the holes and resprayed the bumper.
End result didn't look quite right though - lacked aggression (?)
Old 11-13-2002, 12:15 AM
Frenchie's Avatar
You could compromise and do what Leggy Blonde has done, which is have the washers sprayed the same colour as her car. Look good!
Pete
Old 11-13-2002, 03:50 AM
arsie's Avatar
No big deal but I can't see where the pink fuse is now - but nice to have these pics, BS
Old 11-13-2002, 04:34 AM
Frenchie's Avatar
I keep mine in the space on the right of the box
Old 11-13-2002, 04:43 AM
DaveKing's Avatar
Mike did this :
http://www.s2ki.ch/users/neuweiler/
It does look less aggressive and although I will definitely lower the numberplate, I will not remove the "squirters" on mine
YFZ450
07-30-2012 04:09 PM
captainbk
04-24-2007 06:11 PM
Wankel
Member S2000 Classifieds and For Sale
02-28-2003 07:32 PM
Frenchie
06-16-2002 03:58 PM
Y2K++S2K
01-14-2001 11:08 AM
Quick Reply: Killing the Headlamp Washers
