Lacquering my nice 6 spokes BBS
Banned
Originally Posted by Bassoctopus,Dec 21 2007, 08:34 AM
Cheers Gad,
At last some sensible advice
use a very fine wet and dry on the areas you are spraying (something like 1000 grade, used wet in soapy water
rinse clean
dry throroughly
spray them indoors, in a warm room - make sure the wheels have been in the roam overnight so they are the same temperature
before you spray, go over them with a tack rag to remove dust - if you can't buy one, make one from a ball of sellotape
warm the spray can in a bowl of warm water for 5 minutes or so before you start
always spray over a wider area than you actually need
after a day or two, use an abrasive like t-cut to blend the rough edges where the spray pattern ends
wax
Doesn't sound like a project my wife will appreciate over Christmas.
"Don't worry, I'm just taking over the dining room to lacquer these wheels"
Thanks for the advice. A nice post-Christmas project I think. Or I could always see how much my mate at the local coachworks will charge me!
Banned
if you take your time, you will do a perfectly acceptable job
I will tidy up wheels between refurbs and I am a bit of a perfectionist when it comes to paint
just don't rush it and you will be fine
Originally Posted by gaddafi,Dec 21 2007, 09:03 AM
you can construct a little spray booth from a large empty box
About
Banned
Originally Posted by eSeM,Dec 21 2007, 09:11 AM
Is it common for Notherners to give large empty boxes for Christmas presents?
a) a cloth cap stand
b) a whippet kennel
c) a pigeon cage
