lambda sensor
Old May 31, 2013 | 09:58 AM
VulcanDriver's Avatar
Default lambda sensor
Next week I'm fitting a cat back exhaust system, looking at the lambda sensor in the current cat it looks like its well a truly in. So if worst comes to worst and I have to fit a new one, what do you guys recommend, other than the OEM one. My car is a 03 model.
Old May 31, 2013 | 10:39 AM
MIP's Avatar
MIP
If you're fitting an exhaust system that goes from the cat backward, why do you need to touch the lamda sensor? Are you fitting a decat at the same time?
Old May 31, 2013 | 11:20 AM
Good point. I thought the cat had blown earlier as it was rattling like a good 'un, turns out to be the heat shield had come loose. I was think I may have had to replace the cat at the same time.
Old May 31, 2013 | 11:23 AM
Ultra_Nexus's Avatar
So if you are replacing the cat, why do you need a new O2 sensor?
Old May 31, 2013 | 11:59 AM
The sensor looks like its corroded in. Not tried to move it as the cat is OK.
InVTEC
Jun 16, 2016 01:26 PM
mobile chicane
Jan 18, 2012 05:22 AM
davidc1
Dec 19, 2010 08:44 AM
dominion
Mar 27, 2010 07:59 PM
littleandy
Jun 20, 2006 04:06 AM
